Fuel fikter sits above the fuel level in tank mind, would have to sit the fuel hose below floor of car to check correctly, assuming the fuel pump allows free flow through it in the direction of flow.throttle body is good, it come of a good running car, when I removed the fuel line from the fuel filter and turn the ignition, only a small amount of fuel comes out, which means there is a problem with the pump or dirt in tank
Your point is?the fuel filter is in the engine bay
If the earth point of ypur pump has corroded your pump may not be runnig at full voltage due to the resistance at the earth point caused by rust. It could also be the problem you suggested, or a crimped pipe or simply there isn't any fuel in the tank and your fuel gauge/sender is faulty.sorry can you explain a bit more about the earth please, also can it be a problem that when the fuel runs low that the pump is sucking in dirt, as the problem only happens when the fuel gauge drops to the beginning of the red of the fuel amount? the fuel in the tank is dirty, the original pump from the car was also dirty, the mesh on the fuel pump was full of dirt
Tank should be steam cleaned ideally, be VERY wary of leftover petrol fumes. No smoking etc. Avoid chemical cleaners that can perish seals on injectors when they get washed down the system with the petrol later on. If you find it has holes in it after you clean it, you can't weld it until it has been aired out for at least 3 daysthanks for your response, I will check everything out tomorrow, is it possible it can be a ECU fault and how can I clean the tank?
thanks
Thanks,Tank should be steam cleaned ideally, be VERY wary of leftover petrol fumes. No smoking etc. Avoid chemical cleaners that can perish seals on injectors when they get washed down the system with the petrol later on. If you find it has holes in it after you clean it, you can't weld it until it has been aired out for at least 3 days
what do you think the issue is please?
