J
jambaps ca18det
hi my names jamie and im form swansea south wales .
am about to attempt to fit a ca18det in to a micra and make it rwd
jambaps ca18det said:hi my names jamie and im form swansea south wales .
JamieGti said:Welcome!
Hmm... good luck to you, tha't's going to be one hell of a project! fwn
How are you going to go about doing that? I'm sure everyone here will be dying to see your project
Another Jamie... we're mass producing! :laugh:
-JGti
jambaps ca18det said:i plan on using the rear sub from s13 and relocating the fuel tank in to the boot i all read have a s13 enging gear box loom but the chassie is rotten so time for a sleeper
it will have to have a huge wide arch kit and also be lower than snake ####
JamieGti said:Don't know if you want to make your own but kristian posted this earlier...
http://www.micra.org.uk/t1553-works-wide-arch-rally-kit-for-sale.html
Great for just £500 and an extra £500 for spray and fitting!
Other than that, GOOD LUCK!
You're braver than most! haha! I don't know how you can make a wide arch sleeper... i think most people will have a guess that it's fast when they see a set of 295 tires on a micra!
-JGti
micra man said:Welcome to the site, and good luck with the project, looks like you are going to be busy!!! Hope you get it done.
jambaps ca18det said:the engine is currently in my 200sx s13
here goes
garret t35 hybrid turbo
lightened and balanced bottom end
hks ajustable actuater
kent adjustable racing cams
uprated fuel pump
z32 afm
saab fmic
stage 3 chip
fusion coated pistons
@ 17psi = 320 bhp 0-60 in a mear 4 seconds
