new to the site.... need some help
hi to all...... had a question....... micra theft in my area is on a high.... so i got a steering wheel lock and gona fit some alarm led bulbs..... i got 2 wires to fit..... a 12v positive and a black wire to be fitted to an ignition switched supply..... this is so the leds only flash when the car is of and the key is out of the ignotion....#
question is does anyone know where is the best place to find the source wires??
regards
adz
Thanks for the reply..... car has got a factory chip key engine immobiliser.... problem is i heard the scum are using a tow truck.... so the cut the handbrake cable and put it on the ramp.
I just wanted to add a small visual deterant.... but i guess you are right and it might be a smarter idea to get a full aftermarket alarm...... just feeld like the cost of fuel and everything else is going up so i was trying a qwick fix solution.
do you have any knowledge on a middle de-cat?? whats the best way to do it??
many thanks
adi
if i were you if your going to use some leds id run the live to the live for the radio as that has a permanent feed and then im not sure about the other... have it so its always on?
