New Stero/Sub/AMP
Joe.Powell
Ok, so Ive been reading on the forums, and decided to join, so HI!
Anyway, back to the matter in hand.
I have recently Purchased a combo Headunit, and Sub/AMP, really only wanted the Sub, but the headunit will do until my budget comes through.
This is all I have purchased, what will I need to install the new HU?
Also, where is the whole to put a wire to the battery? Am I being blind?
Any Help/Advice would be greatly appreciated.
Joe
P-Reg 1996/7 1.0L K11 Vibe
hi fella and welcome
you will need a iso adapter for the head unit
on the cable for the battery if you look on passangers side of the car there is a gromit you need to make a hole in it and thred your cable threw i can get pics if you like
they will know and its really easy will get a pic in a mo
under the dash next to the footwell for the passanger feet there is a black box attatched to the car using 2x 10 mm nuts losten them off and pull the black unit forward a little bit and you should be able to feed the cable threw the gromit and then into your car if you sign up as a member there is a guide showing you how to do it
Cheers, I think I will join, been pondering over it for a while, will I get all of the info on the Bronze membership?
