I predict a hi 13's to low 14's for cisco at a terminal of around 102mph. His turbo has a poor boost treshold, that will make a good start very hard and with a narrow power band, the all or nothing effect, so bog down or burnout.
As a passenger it would feel very fast but if you look at his torque curve, there is more area above the curve than below, which is not ideal, and really means he has to use the revs, which with a high enough limiter, if he can fall back into where the car makes boost after changing gear it will be ok, otherwise he will suffer really bad inbetween gearchanges - again it will feel great fun as a passenger, but makes for a really hard drive under race conditions.
