Right many of you may have read a couple of threads i've started about gearbox/clutch issues with my car. i think i have come to the conclusion that the gearbox has had it! Its done 117k miles and it's getting very hard to select first gear, i think the clutch arm mech may have something to do with this as i am always running out of play to tighten this up. i have fitted a new clutch and clutch cable, i have no problem engaging any other gear when on the move, occasionally reverse may crunch a bit but first is really hard to engage most of the time, although every now and then its easy!
I believe frank did have the suggestion of changing the rear engine mount but i haven't had chance to take a look at this properly yet and i never got round to buying a replacement from another member on here.
Any suggestions as to the best way to proceed would be greatly appriciated.
Matt
Matt
