D
Dust
I want to first say that the manual is on the way, but it's an 8 week journey here from England. So please bear with the timely questions that I need to ask.
First, oil filter location. I did a search on the board, and didn't come up with anything. The oil needs a change bad, but I can't find the filter.
Tranny. I get a really hard shift the first 1-2 shift of driving before the car gets warm. I have Dex 3, but I haven't been under the car to look for the pan drain plug. I will crawl under this afternoon and take a look around.
Coolant. She is drinking coolant. Only does it when the car gets up to around half on the cluster. I think I have found a holey hose, the bottom hose where it attaches the the engine, and I will get it fixed, and the tires replaced, as well as the belts and maybe the passenger cv joint. I have no steamy exhaust, but I saw some junk in the radiator, and there was a bit of green below the crack in the hose. I don't know if the junk in the radiator means a blown HG, or just the coolant that was replaced was cleaning up the probably abused cooling system.
