Hey thanks all. I will try tonight. From what I understand I must not touch the flat head screw on the side of the carb as this is to adjust the mixture which is spot on.
To adjust the idle I should find the cross head screw located at the back of the carb (between the throttle cable and the base of the the bracket that holds the o
