B
bweengmachine
young irish male, with a import k10 micra (march) and in disperate need of advice. I need more power will putting a european carb on my car effect my proformance eg if i bypass the ECC, and if so will a 1.4 sunny carb fit on the 1 litre inlet manifold. also will a k11 sixteen valve head fit on my block ( one litre) and also what must i skim the head by to bring up the compression ratio to 10.3:1 (the highest recommened factory ratio) also will a 5 speed box make alot of differance:k10: fwn
