Well the brake vac pipe isnt the culprit, i've had the whole inlet off again and thouroughly checked every aspect that could possably cause a leak and i just cant see anything!
no i didnt use any sealant the gaskets where dry when i fitted them.
i'm out of ideas, its somthing on the passenger side causing it, its almost like theres no vacuum when i put my hand over the weber? could there be another possable cause? could a blown headgasket cause this? i've looked at every possability i can think of on the inlet side.
i have good news its running! got it going on the standard carb, i think its the gasket i fitted to the passenger side weber, probably compressed alot more since the last time i tightend it, i will av em of again and redo the gaskets, should sort the problem.
