CMF_malindags » CMF Member Colombo, Western, Sri Lanka Member since: Posts: Sep 17, 2005 #1 Hi, Need to know how to remove the OEM air bag steering wheel safely in a K11. Thanks -Malinda
CMF_NotAnotherSSS » CMF Member Brisbane, QLD, Australia Member since: Posts: Sep 17, 2005 #2 First disconnect the battery. This will help prevent any chance of the airbag module going off while you're removing it. The airbag is physically fitted to the front facia of the steering wheel, and naturally this has to be removed before you can get anywhere. There should be some flaps you can open up on the steering wheel which should expose the screws to remove the front centre cap/airbag module. Goodluck and be careful!
