Need fuel pump relay MElbourne ASAP!!
CMF_frank2
mycra WROTE:
"Bloody how this is pissing me off.. Just replaced
The relay its still ticking on and off!!
i would check the 12v feed to the relay is constant with a voltmeter mycra, then check the earth via the ecu is constant (my main ecu plug has to be fitted slightly crooked for all the pins to make full contact)
CMF_mipcar
Mycra, just a question left of centre. Do you have any sort of immobilsor fitted to your car? I once tossed out a perfectly good fuel pump thnking it was faulty and it was the immobilisor cutting in and our randomly. My immobilisor worked on pump and ignition and starter but was only faulty to the fuel pump.
Mike
CMF_mycra
Wooooo very good point... Il look into it, chasers did short circuit my alarm A while back... Thanks for all your replys everyone!!!!!
I'm taking the Micra to lakes entrance then to Sydney along the coast on the 31st, lets hope everything stays together!!!!
