Nats ???
I've been offered an 'M' reg K11 thats a non runner, from the symptoms I was told it sounds like a NATS problem, was it fitted to K11s that old ?
I can tell you for a fact that my 1.0 M-reg K11 'Lowest spec' didn't have NATS but maybe the higher specs did. What trim level/engine size is it?
its probably got the very early version immobilizer, which the remotes normally fail could be a simple remote needs changing and coding,
remote -about £65
coding - what ever you local nissan dealer charges
this is the immobiliser unit from behind the center console, does anyone know if its removeable from the ignition system and if it is HOW ?
micra mauritius 001.jpg micra mauritius 002.jpg micra mauritius 003.jpg micra mauritius 004.jpg
