Paul Smith Site Supporter Mar 22, 2014 #1 Has anyone swapped between the two and noticed any obvious difference in power or drive ability?
frank Club Member Mar 22, 2014 #2 the maps will be more related to what car it came off surely paul ?
OP OP Paul Smith Site Supporter Mar 22, 2014 #3 I was thinking if the 1l non nats ran a different map to 1l nats and same again with the 1.3. Wasn't sure if there were any updates with the later map and if it felt different to drive
J jk9194 Jun 12, 2014 #4 Sorry for hijacking thread. Which is the best choice to use nats or non nats for turbo 1.3 conversion? Sent from my iPhone using Tapatalk
frank Club Member Jun 12, 2014 #5 jk9194 said: Sorry for hijacking thread. Which is the best choice to use nats or non nats for turbo 1.3 conversion? Sent from my iPhone using Tapatalk Click to expand... you can have a nistune fitted to either jk
J jk9194 Jun 12, 2014 #6 Thanks. By the way, Is it easy to swap with nats for non nats? I got non nats micra ATM so I want to swap over everything in nats micra. What do I need to swap? Is it only ecu and loom right? Sent from my iPhone using Tapatalk
pollyp Club Member Jun 12, 2014 #7 ecu, cabin loom, transponder sensor, key chip, blocky NATS type key body
J jk9194 Jun 12, 2014 #8 Thanks guys. I will figure it out soon so I can sell non nats or swap over with nats micra if I get one. Sent from my iPhone using Tapatalk
