right ive swapped every bit of loom over from the primera into the micra for the sr20 swap but the nats doesnt work im i right in thinking on primeras nats kills fuel and spark. is there anyway to bypass nats v2 or do i have to get it removed by ed?
have you tried puttin the primera key in the centre of the ring that goes around the ignition and trying to start it? or put the chip from the primera key into your micra key?:
97 k11 , trying to use wrong key to start,,ENG CHK light flashing so wrong nats key is showing eng chk light would flash at a nats fault ? if your bulbs in
right been reading online that nats cuts signals to the ecu what i wondering is if there is any sort of coding in the actual ecu or if i could just remove all traces of nats and bridge the wires?
