Taken from Articles:
"Sunny/Pulsar GTi-R AD22VF front brakes
So you don't think N14 brakes will be sufficient? You must be planning to run a fair bit of power through those front wheels? No worries, again Nissan has thought of micra owners like you by making the Turbo/4WD GTi-R brakes a straight bolt on! The only trick is that you will need to space the calipers out from the hub with some 1mm washers as the two cars have very slightly different mount offsets. But that's no big deal, washers cost about 1 cent.
I would only recommend these brakes for micras running high powered turbo conversions really. Pretty much anything else can be pulled to a fade-free halt by the above-mentioned N14 1.6 pulsar brakes. The AD22VF GTi-R brakes are a bit heavier aswell, as they bring increased unsprung weight (more load on your suspension and ride etc) - so only go for them if you absolutely need them. If you do decide to install these heavy duty brakes, you can make up for the slightly inreased unsprung weight by throwing on a set of lightweight racing rims!"
I guess it will fit
