Hi , going to post all my turbo build here and my queries if that's ok .
Car is a 97 gx 1.0 Micra, has had full respray in Atlantis blue BMW with full march g# body kit and spoiler.
Will be running car at low enough boost about 5 or 6 psi until confident it can take more
Engine spec as follows:
1.3 cg13de
Timing advanced
Autosprint reground cams 272°
Polish & Ported head
Lightened flywheel
D1 spec fuel regulator
Walbro 255lph fuel pump
Cg10 crank pulley
Oil pump refurbished
New valve stem oil seals/rocker seals, crank seals...
New rings/bearings/timing chain
Mitsubishi evo aftermarket twin core radiator
Tdo4 from Mitsubishi gsr
Glanza actuator( for time being)
Bright Spark racing turbo manifold (being made)
Aem wide band controller
Few bits still to get such as injectors, intake Mani, intercooler, ecu, gauges, boost controller, piping, full exhaust...
1.3 cg13de
Timing advanced
Lightened flywheel
Cg10 crank pulley
