Hello, my first post!
I bought a lovely little 2008 Micra 1.2 Acenta+ for the princely sum of £900 about a month ago. Seller wanted a quick sale and so it worked out nicely. It has just gone past the 80k mark and has been doing 48-50mpg indicated no problem at all.
So far very pleased with it, I have driven several Fiats in the past and so am used to little engines performing well enough. Pleasantly surprised by the 1.2 unit, it's got enough poke to get around the hills down in the South Hams!
I have got a problem which I think may be a broken washer fluid pipe. I have used quite a bit of washer fluid this week, the other day I heard sloshing sounds when pulling away on a hill. Have since checked the carpet behind the drivers seat and it is completely soaked.
So my question is - does the washer pipe run down the driver's side? If so, is it easy enough to get to or would it involve stripping the car down (not my forte it has to be said)?
Many thanks in advance for any suggestions, appreciate it might be something completely different!
