must do things to your micra, weather its for the funnies or for real...
CMF_frank2
solar panel to charge the battery, in the sunroof hole is a must in the sunny whether :)
CMF_frank2
david WROTE:
"what fuel savings would you attribute to the solar panel, if it is measurable at all?
i,ve no idea david, i can commute (35miles) with the alternator belt removed in mid summer, and run the alt with a 2 x bigger pulley (and very slack belt) for the rest of the year
CMF_sr20micramike
frank2 WROTE:
"david WROTE:<BR><BR>"what fuel savings would you attribute to the solar panel, if it is measurable at all?"</DIV><BR><BR>i,ve no idea david, i can commute (35miles) with the alternator belt removed in mid summer, and run the alt with a 2 x bigger pulley (and very slack belt) for the rest of the year
why would you want to??
CMF_Greo
Reduces the forse applied to the engine pulley, Therefore using less engine power than standard and Giving more power to the car to drive with. instead of reclaiming electricity through running the alternator
CMF_sr20micramike
Greo WROTE:
"Reduces the forse applied to the engine pulley, Therefore using less engine power than standard and Giving more power to the car to drive with. instead of reclaiming electricity through running the alternator
the gains would be minimal though, probably a percentage of one bhp..or kw
you would probably gain more power improving the aero dynamics of the micra?
CMF_Jon (2)
sr20micramike WROTE:
"frank2 WROTE:
"david WROTE:
"what fuel savings would you attribute to the solar panel, if it is measurable at all?"</div>
i,ve no idea david, i can commute (35miles) with the alternator belt removed in mid summer, and run the alt with a 2 x bigger pulley (and very slack belt) for the rest of the year"</div>
Saving fuel in a micra? Haha they use bugger all anyway!
