Dear Forum Members,
I have a Nissan Micra 2009 (25th Anniversary Edition) . Had my MOT recently, which it passed first time. However it had the following advisory's, please could someone explain to me whether these would be costly to fix or not (and also what they mean if possible) ?
"Front Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. "
"Nearside Front Lower Suspension arm ball joint has slight play"
"Rear Coil spring corroded both side "
For either items 1 or 2 the garage said you should be ok for another 3-4 months - but I can't remember which item !
No.3 was also an advisory last year
Thank you in advance.
