Hi all,
My Nissan Micra 2009 had 3 MOT advisories last year, and 2 this year (at different garages) - however, only one of them appears on both years:
Nearside Front Suspension arm ball joint has slight play - what does this mean please, and should I get it fixed now given it's appeared two years straight but still passed?
The two I had last year which didn't appear this year are as below - I'm wondering why one garage would see them as advisories, and the other not at all? Should I do something about these ?
Thank you for your help and advise.
- Rear Coil spring corroded both side (5.3.1 (b) (i))
- Front Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (1.2.1 (b) (i))
