Hi guys,
I am going to replace my fuel pump because my Micra won't start (the engine cranks). I bought a spare fuel pump from Autodoc. However, I just realized that I may have bought the wrong part because the flow rate is only 80 l/h whereas most of the fuel pumps that will fit a Micra have a flow rate of at least 90 l/h.
Can I use a fuel pump with a flow rate of 80 l/h? Everything else seems to be compatible, the hoses, the connector, the filter sock, etc.
I really do not want to exchange or return this one because I will have to send it back to Autodoc based in Berlin, the postage will cost more than the fuel pump itself.
Thank you, guys.
Thank you, guys.
