hi guys,
Ive been running a lot of checks on my 95 micra 1L., since it decided not to start and have found out the following:
Good spark, in fact the car starts and runs when i spray petrol direct into the air intake.
I did the throttle re solder to no avail,
I ran the diagnostic on the ecu, it came up No malfunctions.
The fuses seem ok,
I think the problem is at the injectors because the fuel is pumping up that far but the injectors are not opening when the key is on. the common wire to them is ok but no activity on any of the individual wires thet run to the ecu
any ideas???
The fuses seem ok,
any ideas???
