Hi everyone,
Im new to these forums so please bare with me.
My wife has a Micra K12 E (03 plate) and we bought it last June. It was working perfectly fine until the winter started.
We started to notice that whenever we left it sitting over night, it will fail to start in the morning unless you had your foot on the gas first and revved it up! However, once it had idled, it would work like a dream - still the case.
Recently however, it's been getting worse and worse - even though the weather has been getting warmer, and we've started noticing it's worst when parked uphill (we live on a steep hill). It requires just a tad bit of gas to get it going and stabilises within 5-10 secs. Once it's going, you can turn it off and on a million times without gas and it works perfect. To add to that, if you don't gas it first time and it stalls, it refuses to start for 10-15 mins.
The nature of the problem (have to leave it over night for it to reoccur) means that the garage holds it a few nights each time and it's getting annoying.
I've just dropped it off again. In the last 3 months I have changed:
The crankshaft + camshaft sensor
Spark Plugs
Used Carburettor cleaner (dad's advice - helped a little)
I've cleaned up the inlet and also throttle body and also changed the air filter.
I have noticed there is a tube inside which doesn't seem to connect to anything and don't know if that's related.
The car accelerates and drives perfectly and only done 44k. I always keep it above half full on petrol. I went to Cardiff (from London) and back over the weekend and it had 0 problems. Engine light is not on (never has been) however my rev meter is really funny and gets stuck at 1-2rpm (will go up but not down, but intermittently works normal)
Have full service history so I doubt it's been tampered with for the odometer.
Any advice is appreciated. And a huge thanks in advance.
Tezza
Today's Video -
Last Time (1 month ago) -
Spark Plugs
Tezza
Today's Video -
