micra will not start after moving a few meters
CMF_MicraNut
Hi all,
My 1998 nissan micra will not start again after moving the car just a few meters. The engine was cold when i moved it a few meters, stopped the engine and now it will not restart again. The starter is operating fine and the engine wants to turn over but it just will not start. I have had this problem before. Does anyone know of a fix for this?
CMF_jonty4
This is a fairly common problem.If you start the engine and only intend to move it a short distance,let it run for a while and then turn it off. A couple of minutes should be fine. The reason is the engine tends to be overchoked when starting from cold. Hope this is of some help.
John
CMF_MicraNut
John T. WROTE:
"This is a fairly common problem.If you start the engine and only intend to move it a short distance,let it run for a while and then turn it off. A couple of minutes should be fine. The reason is the engine tends to be overchoked when starting from cold. Hope this is of some help.<BR><BR>John
Hi John,
I had a feeling that this might be the problem. Thanks for the reply.
