I'm considering lowering my K11 but im not sure whether i actually need to buy lowering springs. Are the springs on the K11, tension springs (allows you to lower the car manually with a few tools and at no extra cost)?
No - your better buying sprngs made for it. I belive Gmax make sprongs for the K11, this will give you a 35mm drop, if you want lower, then you'll need to get some custom made
i think its recomended to ugrade shox wen lowering,but i didnt and have no probs,,obviusly you will get more from them with kyb/konis,but its not needed no mate
in this post it says that micras have better suspension than the saxo etc and if modified correctly can be amazin, wat mods r needed to reach this standard?
the whiteline kit is from australia, the full kit is quite expensive,not sure on the exact price, i'd just get a whiteline adjustable panard rob and a strut brace, thats all u'll need realy
