Micra SR20
Hi , doing my 3rd SR20, first was a 250 brake turbo. Does anyone have a drawing how to pair the Almera gti ecu wiring with the K11 wiring, all help much appreciated
If its an engine conversion you shouldn't need to join the 2 looms together...
The almera ecu should only need to run the engine anything else without a complete loom swap is a waste of time
Thanks guys, I have a full doner SR20 K11 with Mera loom, but I want to keep the Micra clocks and all interior wiring. I am doing a full nut and bolt rebuild as well as a full underbody hand paint. This will be my last SR20 and want it to look as standard as possible.
