Hi
Need a radio code for Micra.
Serial number
BP536556437839
Any help will be really appreciated.
Thanks.
Serial number
BP536556437839
Thanks.
Try 4209 or if that fails the alternative number is 0209Hi
Serial number
BP536556437839
Thanks.
Hi Alan, try 3882 or 1882...Hi need radio code for Micra 2005 1lt.
BP334947319006
55610163229
Thanks,
Alan.
Please can you help me too?Hi Alan, try 3882 or 1882...
Hi Hannah, try 6494 or 0494....Please can you help me too?
Try 5217 or 1217....Hi there, could someone also give me a code too please, the code is bp 538471203970
Big thanks
Tried both of them and double checked the code but still not working, anything else I could try? I have the other part/serial number if that helps?Try 5217 or 1217....
Anyone else got any ideas, still can’t get it to work, when you input the numbers it just doesn’t do anything when u press the up button. Doesn’t tell me wrong code or anything the number just stays there. I can get the radio to Work temporarily (when you do the trick with 1 and 4 buttons) and the scan up button does work on the radio setting, so it doesn’t seem to be faulty.
I’m a bit lost with anything else to try. I’ve double checked the numbers I gave in the first couple of posts and they are correct.
Anything else I can try?
Thanks for your time
Fantastic John d...I’d not thought of a different enter button!! TA worked the magic. Thanks so much for your help, very much appreciatedCodes right, you just haven't found the right button to input the code. Try pressing different buttons after typing the code in.
Hi try 5919 or 1919.....Hi. Can anyone help me please with radio code.
Serial number: BP334947263809
8635123392
Thank you in advance
Hi, try 7921 or 1921.....New #34
i I have no idea which is the serial number >//?
On the radio is the following
BP334936356522
Then Nissan 7 643 349 318
e1 022458
28 185 AX613
HP-3064
55610021062
nissan MM CD-K (BLK)
Is any of those the radio code ????????
Hi, try 3915 or 1915.......Hi could any one please assist me with getting my micra’s radio code had to change the battery and now i cant find where i wrote the code down sn: bp334947333084 and pn: 8 635 123 393
Hi, try 2984 or 0984....Hi, is it possible someone could help me with a radio code please. Just bought a 2004 and the radio is asking for the code and i have no handbooks ?. Thanks in advance.
BP3349 3 638 7913
7643 349 318
Hi, try 3782 or 1782........Hi
Looking for a code for my radio
BP538769665541.
Thankyou so much, now have a working radio lolHi, try 2984 or 0984....
Thank you all working ?Hi, try 3782 or 1782........
You remove the radio from dash and it's in a sticker behind the radio. Like in the pictures above.Where can I find the serial number please?
Thanks for you reply,You remove the radio from dash and it's in a sticker behind the radio. Like in the pictures above.
Hi,
Can somebody help me with car radio code for Micra:
BP536258401920
Nissan 7645362318
thanks
No problems, try 6202 or 0202...........Hello everyone,
The usual problem, have brought a Micrs SX dci and no hand book therefore no radio code. Clearly the previous owner had a battery changed at Halfords without keeping a voltage on the car. Result, lost coding. Both my other two micra's came with codes. I have the BP number as below but the part number (11) digits starts with 86 when everyone else seems to start with a 7.
Any help is greatly appreciated
BP334947332940
8 635 123 329 0
Regards, Micra survivor
is there any other way to get the serial number without removing the radio?
I have code 0000 displayed on the radio.
Hi, try 8132 or 0132.......Please can somebody help me with the radio code Blaupunkt serial BP234746080887, Nissan part number 7642347318? I watch YouTube on how to remove the radio and it helped,
thanks in advance
Hi, try 4689 or 0689.......Hi,
Can somebody help me please with car radio code for my Micra:
BP538469511766
7645384318
many thanks
Hi, try 5725 or 1725.......Hi !
Sorry for the latest post...
Can you help me with my radio please, i'd like to listen music again.
Here is the number :
BP3349 4 7305746
Nissan MM CD-K
7 643 349 318
Thanks a lot again
