Micra Part availability??
CMF_Hung Sam
Hi everybody, i am considering buying a used nissan micra. I have read few reviews about the car and really like it. My only concerns is that parts availability and repair cost of the car. Could anybody give me a general idea of how expensive it is?
thank you very much.
CMF_mipcar
Hi Hung, Welcome to the site.
Some Nissan parts can be expensive but will generally be available (sometimes with a delay ) from Nissan dealerships.
Normal service items like filters etc are normal price.
The are a few aftermarket supplies available for the Micra but it depends a lot on where you live.
Generally speaking the car never gives much trouble and there is lots of advice available on this site.
Mychael
CMF_NotAnotherSSS
Parts and servicing is no more expensive than any other Japanese (despite it being made in the UK) car. In my opinion and from my research on them, they're actually cheaper to service and buy new bits and pieces when compared to my Japanese made and imported Nissan Pulsar SSS.
The only downside is that parts at wreckers and at nissan dealers are usually in stock whereas you have to order them in for the micra. This is usually only components which dont failt too often though...
As for bodywork, don't worry too much about that. The micra is in the same class as every other car in the under $10,000 price range. If you crash it at a speed over 20km/hr, it'll probably be written off because the repair will exceed half the car's market value. There are some exceptions there, but I personally wouldnt give a rats about it. :)
The most EXPENSIVE thing about owning a micra would have to be the modifications. Once you get a taste of what these spirited little cars are capable of with just minor modifications you'll be hooked and the hole in your wallet from modifications/additions to the car will just expand. I believe cisco has a disclaimer about it somewhere on the site. Shame i didn't read it before I started looking for a Micra....
Cheers and Good Luck!
CMF_Ghetto Micra
now for my opinion (everyone gasps as Mr Evil himself types his stuff)... :)
The micra is a cheap car to RUN.. but an expensive car to MAINTAIN...
panels, not a prob, bingle one up and you can get them from ozeparts pretty cheap.
mechanical.. EXPENSIVE.
For example, if you need to change your timing chain(s) or associated parts, get ready to shell out over $1000 in PARTS alone.
New mechanical parts are damn expensive, anx ex Japan/UK. Nissan dealers rarely carry the parts required for Micra's. If you walk in and say "i need a door trim" or "a bumper" or "a gear selector rod", they will say, sure thing, it'll be 2 weeks (or more)
Parts are not as easy to get as some people think (new parts anyway).. if you live EAST of aus.. you will probably have a tad more luck than us westerners.. (some of our nissan parts come from east, but are more often than not, ordered direct from JAPAN).
It might cost a bit to maintain, but it's an "easy" car to maintain, very simple lay out, very straight forward motor/mechanicals. You can do most mechanical work on the car yourself probably, even if you only own a socket set.
Many micra's were used as either hire cars, or learning vehicles in australia, meaning many are either thrashed, bent, or ex-prang cars or all of the above, you will need to be careful when buying one. it's okay to buy one that's had damage, so long as it's well repaired. (mine had panels replaced as it was in a bingle, but the chassis is straight and everything is fine :)
I gotta admit, it's a fun car to have. Add the whiteline suspension (all of it) and you wont be able to get the smile off your dial... all the micra really needs is some GRUNT. unfortunately it's really underpowered (but what do you expect for a car like this)
A well built car that out-classes it's rival's (such as hyundai excel) mainly due to build quality.
The micra has cool features which other cars skimp on.. such as (my favourite feature), a fuel lid holder inside the fuel door. I love sitting my fuel cap in that holder as I fill up at the servo, no putting the cap on the roof of the car... well fitting interior panels, easy to access wiring, many compartments, nice layout of interior...
I could go on forever. I should write a "james review" of the Micra. I've not been a Micra owner for as long as some of the die hard's around here, but this is an honest review from someone that has owned some seriously modified, and classier cars in the past...
The micra has a feel, or a presence if you like... an aura, some kind of cult following and feeling.
I'm looking forward to driving my Micra home from work :)
CMF_White Knight
Why bother. If timing chain stuffed put in a low kl.jap spec motor for half the price of a new timing chain.
Source second hand parts. A great place is www.grandauto.com.au who specialise in Datsuns/Nissans. I picked up a near new coolant overflow tank from them plus they rang me to see if part was okay and also received a fridge magnet.Wow you might say re the magnet but coupled with a phone call they have got me.Throttle body well that is now an easy fix.
A little off subject but I see small car sales jumped 25% in Aussie over the last quater and is now the fastest growing car segment.Fuel prices fuelling ( a pun in there?)the demand.
Go Micra.Maybe Nissan thinking hard about the K12 for Aussie.Be good to blow em off the road.
K11s rule okay ??
CMF_NotAnotherSSS
Those turbo diesel K11's will be a menace within the speedlimits with their bucketloads of torque.
The fuel economy and kick in the guts they give would be pretty damn attractive for someone like myself though.
CMF_Ghetto Micra
it may or may not cost up to $1000 aus to do a timing chain job, thats worst case scenario with parts like:
two chains
two guides
two tensioners
seal/bearing
two cam gears
idler sprocket
crank sprocket
if it's just a worn guide or tensioner, it's a cheaper fix..
I need to do mine, it's noisy, I think the best way for me is to inspect the motor for wear, and replace just what needs replacing... that means pulling the motor apart, THEN going to nissan to get the required parts... unless i can get some nissan friends to hit me up with the parts in advance, and what I dont need I can return to them at no cost.. hahaha
problem with just getting another motor, and plonking it in, is you risk getting a motor with a timing chain or other problem... hehe
