Micra MG ZR Spoiler for £14.95 Brand new
Just thought I would share my find of a bargain shark fin spoiler for our micras, it is available in all usual colours red, black, blue etc
Red here - http://pages.ebay.com/link/?nav=item.view&id=290998506728
Black here - http://pages.ebay.com/link/?nav=item.view&id=290998509972
And Blue - http://pages.ebay.com/link/?nav=item.view&id=231076282058
You will need to mark up template using card and drill 4 x 6.5mm holes and fix securely using m6 x 50mm bolts although only 2 need to be that length and just chop the other 2 down a bit.
Connect up to existing high level brake light and finish seal with clear or colored silicone.
Update, just finished fitting my spoiler and I will be brutally honest.
It was harder than I thought it would be to fit, main problem making sure that the 4 fixing points are EXACT otherwise it won't line up. Also I had to ditch fixing it with bolts and called to Wickes for some M6 Studding and a bag of nuts and washers. I had to drill an extra hole for the cable from the integral brake light on the spoiler then split the cable from the original high level brake light and link them with a bit of 5A connector block.
I am self confessed novice and the fitting of this MGZR spoiler is not for the faint hearted.
