Micra K12 wont start . and some times start and when stop it and try again wont start
Micra K12 not wont work sometimes
  • is it relay ?
    Votes: 0 0.0%
  • is it fuel system ?
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
I have Micra K12 - 2003 . I installed new engine and when I try to start wont go up ,
sometimes start and running , but when I stop it " off "
and try to start again wont to start
I checked the
all the fuses = good
relys of IPDM = ok ---- just one I think id not good
fuel pump = good
injector = good
ignition = good
could please help ?
any wiring diagram nay service manual ?
Hi.. I had the same issue after changing the 'Battery'..
Apparently the NATS stop the car to start. As far as I know.. The fuses near the steering wheel - fuse number 6 or 10 (something like 'i-key') Take the fuse off for minute or so and then put back the fuse and try again.
I'm not 100% sure that will do but worth trying.
Good luck
Hi azb786 , thank you very much for your replay ,
where is NATS ?
Could you please,, put some pictures, the place where this fuses number 6 or 10 ?
looking for your help
thanks
Ashraf.
Ashraf..
NATS is the security system for Nissan.. I really don't know the locations of where and what you can do with the NATS..
However here is some pic I found through the forum. (Thanks to the guy who posted it). These pic will give you some idea where the fuse box is located and the fuse you want.
Once you take the cover off.. The fuse is the 7th (maybe the 8th as well) one on the top line, see 'BATT' - '10A immobiliser'.
Remove that/them fuse off and disconnect the battery.. Leave it for 10mins or so.
Connect everything (battery, fuse (both)) and see if that does the trick.
If that doesn't work then, I can't help you much.. Sorry.
