Help my heater has stoped blowing on all 4 settings .
i have removed the parcel shelf and drawn out the resistor card
Uploaded with ImageShack.us
The card shows zero resistance across all 4 contacts and the little thermal micro switch atatched to the brass contact makes no diference to the resistance readings .Do these readings mean that the card has gone short circuit as i would expect to see different resistance readings across the contacts .
With the card unpluged and ignition on the blue wire shows 12v . With the engine running the red and yellow wire show 14v .
Ive checked all in cab fuses , The fuses under the bonnet are not so easy to check though .
