I'm new to Micra ownership and prior to signing up checked throught the forum to see if I could find any answers, but I'm stumped....
I've just acquired a 2008 car with 25,000 genuine miles from a family member. When cold the car makes a grinding noise - bordering on a rattle - which can be heard inside the cabin. Oustide it doesn't sound as bad.It doesn't do this at all in neutral, only in drive or reverse. The noise increases with revs. When the car is hot it disappears completely.
Just spent an hour in a pit underneath the car. My partner has been putting it in and out of gear and I can't locate the source. I've repeatedly gone over the heatshields and exhaust to check for any noise. Initially I though it may lie around the alternator area but can't say for sure. When the car is put in neutral from drive the noise doesn't instantly stop and takes about a second or so to decay.
Does anyone have any suggestions?
Edit: I took another look at this today and the noise is definitely from the alternator end of the engine. I also used a mechanic's stethoscope to probe the cam chain cover and the noise doesn't appear to be coming from there, but I can't pinpoint it. Certainly something either to do with the shift in engine position with drive engaged, or the change in loading of some component.
