Hey all,
I have a question regarding the car in the topic. It takes 5-8 seconds for the engine to fire/start when cold or hot or somewhere in between. If you fire it right after a previous ride (5-10mins max) it starts immediately.
I do not have checked the fuel pressure or any valves (IAV etc.) What would you guys suspect the problem to be? I think the idle is a bit low / rough as well but not too noticeably.
Would You suspect fuel pressure issue, leaking injector or any other (fuses, relays)? The -98 model is with the distributor dizzy, not direct spark.
Otherwise the car is really fun beater as a daily, along with Skyline
Thanks in advance!
Thanks in advance!
