CMF_PANDYA
» CMF MemberI sprayed carbon cleaner in carborator to clean ,now she is running rich,I can here high rev when I press cluch down.
any idea folks?
any idea folks?
Danvillan WROTE:
"carburetor? Sorry am I missing something, should be EFI. Could be many different thing from a vacuum hose coming off, to a clogged injector or even a CPU fault. So check to simple things first, if it don't work you may have to get a mechanic to fault find the CPU. Or just drive it hard for a couple of days and hope if something is clogged it loosens up, probably not the best option.When you say carby did you mean the throttle body? It could also be in need of new spark plugs because all the carbon from the intake manifold may have caused the spark plugs to foal up. It's hard to say.
