Reply to thread
Hello K11micra
I repeat my original post on this subject which records" Exclamation  Micra K11 Automatic 2002 ATF OIL COOLER
I changed the ATF over the weekend without problem BUT I noticed a black cannister on top of the gear box looking like an oil filter which I assume is the ATF OIL COOLER
Am I correct and should this be changed? If so where do I obtain a replacement. Is it easy to remove? What is inside the cannister? Your words of wisdom will be greatly appreciated
As you will see I have changed the ATF fluid but wonder if you can throw any light on the cannister which I describe
Any comments K11micra will be appreciated
