Hi,
Over the last week, I have had a problem starting it in the mornings. Turns over fine, not firing. The first three days it eventually started after a number of tries. Engine management light on. My mate put his diagnostics on and it returned code P0335 - Crankshaft Position Sensor "A" Circuit Malfunction.
Replaced CPS with second hand one from a mate who owns a garage. At first try it did not start, so my mate swapped the Cam Sensor as well. It started. Come the next morning, not starting again.
However, if I ever do get it to start it is fine for the rest of the day, until the next morning again. This has been the pattern for almost a week.
I've had the AA out three times. Friday: No start at all. That's when we replaced the CPS. It was not an easy job, could not remove the old one from the casing, had to have it drilled out. Second-hand one put in on Friday. Saturday, I could not get it to start after a number of tries. Called AA and it started on his first try. He advised that I try again on Sunday morning one or two times to see if a fault code is generated. I tried twice on Sunday morning, no start. so I call AA again. When he arrived, put analyser on but no fault code. it started on his first try again.
When the fault is there, there is no spark on plug one. I've got a brand new CPS coming just in case the second hand one is also faulty. I simply don't understand why the problem only manifests itself in the mornings only (when it's at it's coldest I suppose)?
