micra k11 1.3 to 1.4 cams
CMF_giannishazel
hi everybody.i own a 1,3 k11 with 1.0 gearbox and ecu, full exhaust,pink ga15 injectors,airbox ga15(with custom ram air) and throttle body ga15,lighten balanced engine(rods etc)a lot of cylinder head work and now i am at the part of picking cams..i do have a spare pair of 1.4 cams modified to put the distributor but i am not sure about the benefits..has anybody tried the swap from 1.3 to 1.4 cams?any opinions?
CMF_frank2
they,re the same profile aint the gianni, with the same 2 points of contact
CMF_giannishazel
hmmm.i havent compared them yet,cause the 1.3 ones are still in the car but i thought that they could have different specs..if they are the same i will look for customized ones.any opinions?i use the car everyday so i am not looking for "crazy" ones.thanks in advance
CMF_frank2
humphris of oxford sell direct fit ones for about 500 pounds iirc mate, and i liked my 160 pound autosprint reprofiled ones personally, but they were pretty noisy tho, and the bearings are worn out now.
or the piper reprofiles are pretty good
