4wd micra is it possible ?
I think it would be a great project to do although a little on the expensive side !
Has this Been done before ?
Maybe some Australian nutcase has done this
Any input would be great
Anything is possible
The gti-r will be the easiest one to do as you've got the already well documented sr20 swap. Then you've got to mount a rear subframe with everything on that and a prop in between.
It will cost you about £3000 in materials alone including the gti-r you'll have to buy
