Hi All, I have a nissan micra 1.2 03 plate thats developed an electrical problem, when i turn the ignition the only light to come on the dash board is airbag warning light and it will not turn over, i thought the battery was flat and tried jump starting same problem will not start, i've checked the fuses inside car all ok the fuses under bonnet look ok, there is a black relay next to fuses can this be causing the problem any help or advice welcome or is this a garage job.... thanks
Sorry ive posted in wrong forum
