micra de-cat
richarda
ive got a nissan micra vibe 1996 model and im looking for the de-cat pipe for my car. ive checked ebay and ive asked a few of the garages around here but nowhere will do it and im having no luck in looking on the net for the de-cat pipe just wondering if any1 knows where i can get 1 from or a web site that sells them, thanks for ya time guys
they are not that hard to make your self,
i made one for an astra by taking of the cat pipe, holding it in a vice either side of the cat, and cutting out the cat either side, then welding the same sized pipe in the middle where the cat came out,
but when i did it i was careful removing the cat so i could cut it along the sides, then remove the inards, and welded the cases over the pipe, and refitted the heat shields so that to look at it it appeared the same as with the cat.
