Micra 2009 - Changing cabin air filter
Hi I am looking for advice on how to replace pollan filter in 2009 Model Micra. I know its behind glove box but I am unable to remove glove box even after un screwing 7 screws.
Where is the pollen filter?
centre behind centre consule
Time to change - approx. 15 minutes
How Easy to change - moderate
Tools Needed?
no tools needed !
Fitting Stage 1:-
The filter is located behind the centre consule where it slides into a vertical filter housing. From the footwell find the end of the plastic filter. You may need to remove the glove box and or partially remove a consule side panel to see it.
Fitting Stage 2:-
Grip the projecting lug of the old filter (should be at the bottom of the filter) and pull up and out. Insertthe new filter and refit any previously removed items of facia.
Tools Needed?
no tools needed !
Fitting Stage 1:-
Fitting Stage 2:-
I think he needs to know how to remove the glove box. :laugh:
