Hi good people. I am in need of some wise advice.
Nissan Micra diesel on 2003 plate. Not playing ball starting when cold. Have replaced battery for new and given it a full charge. Have replaced all 4 glow plugs as car is now on 150k. Two of these tested faulty anyhow.
Symptoms are:
Cranks for 9-sec in the morning fails to start. 2nd attempt crank another 9-15 secs and car starts and runs fine. Drives with no loss of power. Fuel economy fine.
Stop car and retry from hot cranks but hard to start again. Waits half an hour and car starts after 2-3 secs crank.
Observations:
Alternator producing 14.4v so car battery charging okay.
With ignition switched on. Glow plug indicator light comes on for 1 sec, for off for 5 secs, on for 1 sec..then repeats until car is started.
Voltage measured across battery drops from 12.7v to around 11.5v in sync with the glow plug dash light.
Power is measured at glow plug tip in sync with glow plug light , cannot hear any relay though.
Although it seems the glow plug relay where ever it is appears to be passing current. I have contacted dealership. Who have priced up for a glow plug relay timer and told me where it is located But cannot seem to find a glow plug relay and its location Another dealership suggested the glow plug relay is integrated with the IPDM (Intelligent Power Distribution Module) unit. Could this be the case -
Temp sensor appears to be working. Blue light displaying in dash when cold. out when temp normal. red when car hot (presumably)
This engine is from a Renault and on their forum these symptoms are almost always cured through replacement of a faulty cam sensor. However, nissan dealership parts are saying there is no cam sensor on the micra.
Words to the wise please.
Symptoms are:
Observations:
