Cam position sensor I can deal with, but, I see it also referes to "intake valve timing control solenoid valve" apparently it controlled by oil pressure and can and does stick from time to time thereby not allowing the variable valve timing to do its job. The symtoms were, engine missing then cutting out, usually it would start again but cut out a few miles down the road. Anyone else experience code P0011?
