me again...help with fuel system pls.
hi george here,
tried to put a new fuel filter in the car yesterday - worked ok.
then the car refused to start.
new part being delivered from parts people tomo, a fuel pump.
if this does not cure the prob with starting , what else can i try?
relay for the pump?
gmcn.
you,re having problems with this here car george :eek: you should be diagnosing things first really (before buying and changing parts that are,nt faulty :eek: it,ll end up turning into a moneypit)
a simple multimeter will show if any power is reaching the pump :grinning:
