Matiz setup questions
Have looked at the lowering guide but need a little bit more info...
Front
Im looking to drop about 50mm. is it right that i need the rear springs from the matiz to fit on the front of the k11?
is that just the springs or the whole strut aswell?
Rear
Dont want to cut the rear springs! iv hear suzuki alto rear springs fit the rear of the micra??
Appreciate the help as need to get it slammed on the cheap!
i have alto rear springs on the front of mine ash, and 05 matiz rears on the rear.
that gives a 50mm + drop :)
sounds good thanks! ill get to the breakers asap! do you need to modify anything for them to fit or is it all straight forward? :)
i went to breakers and sorted out some springs. got matiz front stuts with springs and the rear springs also from the matiz aswell. as they had to altos in stock. You reckon this would work if i just swap the standard micra front and rear for the matiz?
Write your reply...
