mass air flow
The Maf is self -cleaning.
Do not touch the hotwire at all. Do not use compressed air.
The quickest & cheapest test for MAF suspected issues is to simply unplug it & test drive to check if the misfire/ kangarooing issues are reduced.
Every time engine ign is switched off the ECU software controls heat up the MAF sensor to burn off any contamination automaticly.
Cheap & or worn out disintegrating air filters can shed paper particles that can rarely form whiskers on the MAF hot wire transducer sensor. Inspection with plus 3x magnifying glasses rqd.
MAF Hot Wire Cleaner ISOPROPYL Alcohol at DuckDuckGo
Much more threads related info at the bottom footer of this MSC page.
Good will hunting fault finding. :)
Thanks mate all new to this.
