D
Deleted member 29304
Hi All,
I have just read in this section that I don't need to worry about filling up the gearbox oil until my k11 1.0 has done 100k, which will be sometime as my K11 has only done 39,000miles. However the car is 14 years old and I would have thought that the oil would worn out due to it's age! Would not be easier if I just change it instead? My only problem is what socket do I use for the drain plug and do I need some sort of sealant for the drain plug once undone?.
Yours Peter0003
Yours Peter0003
