Manual gear box conversion
L
LA_469
hi guys,
need some advise, i thought of converting my auto CG1.3 to manual.
Which gear box set should i use for better performance. the 1.0 gear setup set or the 1.3 gear setup set.
I have read that the 1.0 gear ratio is better.
any advise is much appreciated..
The 1litre gearbox would have faster acceleration but the top speed will be reduced and fuel consumption will be increased. The 1.3 gear box is hardly sluggish and your be alot better fitting that and tunning the engine, also some people belive the 1.3 gearbox is stronger. There are some other differences in the gearboxes but ill leave that to someone else because i dont know.
