Manifold Heat Shield Group Buy!
hoodedreeper
I recently had a cover fabricated for my K11 to go over the existing Heat Shield for the manifold. Its a pain in the a** trying to un-do those bolts and then they snap/corrode off and the existing heat shield is still there,in its lovely rusty/dirty form.
So what better way to cover it/make it look nicer than to have one of these:
Comes in brushed aluminium with pre-drilled holes and already bent to shape!
Can be yours for £25! Will need a minimum order of 5
one hole uses the same hole as the Alternator bracket and the other uses the hole where the lamba sensor bracket is. Used to go over the top of the existing heat shield
a dont have a std manii, was just thinkin because looking at the pics it doesnt look like it would cover much or realt work??
good idea though!!!
lol why wouldnt it really work?...its just the same as standard but looks better it will still block out heat, its not like a heat sheild makes an noticeable diffrance anyway! lol
Bump!
Is anyone interested in these? Just that the company that did it asked about it thats all :)
Payment to: [email protected] (£25)
Subject: Micra Heat Shield
If you could use the correct Subject title,then he'll know exactly how many to do :)
